Question: Text searching problem
Am trying to analyse a set of strings.   Can anyone help?
We have 10 x10 matrix into which we need to add connection score.
ExY := [WPKCPYWFYWCXHY, WPKCTEYFHCFEEE, HYCYTFHYYWWKCE, HYHHTFHKFEYHEH, HKXWYHFECTFFTF, HKWEHPPECWWHTC, HKXWYTPXHFHWYP, HKFEXCTFECXFKP, HKFEYPPEEEPHYW, HYTHCCFEWPPEXX, HKXKXCKFCHTEWK, HYEKPPCKFTWXXW];
Here is the code to create the connection matrix
A__c = A__a+A__d;
Blist:=[W,P,K,C,Y,F,X,H,T,E]:# basis letters
nWords:=numelems(ExY):Wletters:=length(ExY[1]):Bletters:=numelems(Blist):A:=Matrix(Bletters,Bletters):# set up dimensions
for iW from 1 to nWords do  # loop through words
  for iL from 1 to Wletters-1 do # loop through letters of each word
     fromLett:=C(iW,iL); # see char extraction from ExY list above
     toLett:=C(iW,iL+1); # ditto
     BfromLett:=Search(fromLett,Blist);# column id   <<<<<< the search is returning 0, it works if one uses "A" rather than say fromLett=A
     BtoLett:=Search(toLett,Blist);# row id   <<<<<  ditto here
     A(BfromLett,BtoLett):=A(BfromLett,BtoLett)+ 1; # add statistic to the A-matrix
  end do; # end letter loop
end do; # end word loop
Error, index out of bounds
The search function is failing:
Blist; Wletters; Bletters; nWords; fromLett; toLett; BfromLett; BtoLett; A; iW; iL;
                 [W, P, K, C, Y, F, X, H, T, E]
                               14
                               10
                               12
                              "W"
                              "P"
                               0
                               0
                 [0  0  0  0  0  0  0  0  0  0]
