Question: bug in Latex generation
Maple 2018.2 generates wrong latex in this example. In Latex a space in command name is important. So "\tau L" is not the same as "\tauL".  Since in the later case, Latex will complain that there is no command "\tauL"
Maple generates "\tauL" in the latex, when it should be "\tau L" in the following example, so the latex fails to compile because there is no command called "\tauL" in Latex.
Here is screen shot showing the problem and the Maple command to reproduce it
interface(showassumed=0);
pde :=  diff(u(x,t),t)=k*diff(u(x,t),x$2)+(exp(-c*t)*sin(2*Pi*x/L));
ic  :=  u(x,0)=f(x);
bc  :=  D[1](u)(0,t)=0, D[1](u)(L,t)=0;
sol:=pdsolve({pde,ic,bc},u(x,t)) assuming L>0,t>0,k>0;
latex(sol)
Any chance Maplesoft could fix this?
Possible workaround for now is to use something like "\newcommand{\tauL}{\tau L}" in preamble for this specific case.
