Question: Solution control of a partial differential equation
given is the lower, partial differential equation. I have solved this (hopefully) correctly. I was given the tip to do in Maple a simple control in which the solution is inserted into the original equation. Since I'm quite inexperienced in maple, I would like to ask you for help on how I do that best!
Thanks a lot!
Basis equation:
Solution:
