Question: Remove assumption from function - Please help
So I'm running into the problem that when I use an assumption, to say automate dsolving, the solution functions I end up defining, has the 'tilde' variable in it. which doesn't seem to be redefinable. How do I get rid of the assumption, in a defined function, or alternatively, how to do I redefine the variable so the function will use it?
