Question: Parallel tasks writing into multiple files (errors...)
I am trying to parallelize the output of my Maple18 program, such that it is able to write into multiple smaller output files at the same time, rather than into one unique big file spending much time in this operation...
This is the code:
D_vol[p,m,k,l,cij]:=...; #definition
T_O_I:=Matrix(...,5);  #matrix of indices
new_print_F := proc (start_n, end_n)
local st, en, inter, f90code, fcode, iir, ppr, mmr, kkr, llr, ccijr, codefile, fd;
global T_O_I, D_vol, N, p_gamma;
st := start_n; en := end_n;
if en-st < 10000 then
f90code := ""; fcode := "";
codefile := cat("D_st_ij_12_vol_P", N, "-Pgamma", p_gamma, "_parall2_", st, ".dat");
fd := fopen(codefile, WRITE, TEXT);   ###### Option A: using fprintf
for iir from st to en do
ppr := T_O_I[iir, 1]; mmr := T_O_I[iir, 2]; kkr := T_O_I[iir, 3]; llr := T_O_I[iir, 4]; ccijr := T_O_I[iir, 5];
####Option 1: cat###############
##fcode := cat("PDv(", ppr, ",", mmr, ",", kkr, ",", llr, ",", ccijr, ")=", D_vol[ppr, mmr, kkr, llr, ccijr]);
##f90code := cat(f90code, fcode, "\n")
####Option 2: CodeGeneration####
fcode := Fortran(D_vol[ppr, mmr, kkr, llr, ccijr], output = string, limitvariablelength = false, resultname = "t");
fcode := SubstituteAll(fcode, "t", cat("PDv(", ppr, ",", mmr, ",", kkr, ",", llr, ",", ccijr, ")"));
f90code := cat(f90code, fcode)
fprintf(fd, %s, f90code); fclose(fd);     ###### Option A: using fprintf
#Text[WriteFile](codefile, f90code);    ###### Option B: using WriteFile
return 1
else
inter := floor((1/2)*en-(1/2)*st)+st;
Start(uscita_print, Task = [new_print_F, st, inter], Task = [new_print_F, inter+1, en])
end if
end proc
uscita_print := proc (g, h)
return 1
end proc
Start(new_print_F, 1, rows)
As you can see from the code, I have tried with different combinations of options. The errors that I get are:
(only one file: "rows-1 < 10000")
Option1A = Error, (in fprintf) string expected for string format
Option1B = Error, (in unspecified) Too many levels of recursion for display
Option2A = OK (but there isn't parallelism here....)
Option2B = OK (but there isn't parallelism here....)
(more than one file: "rows-1 > 10000")
Option2A = Error, (in StringTools:-Split) first argument must be a string
Option2B = Error, (in StringTools:-Split) first argument must be a string
Instead, if I simplify the definition of D_vol to one single sum (for exemple 2+2), this is what I get:
Option1A = OK (but there isn't parallelism here, and the example is trivial 2+2=4)
Option1B = OK (but there isn't parallelism here, and the example is trivial 2+2=4)
Option2A = OK (but there isn't parallelism here, and the example is trivial 2+2=4)
Option2B = OK (but there isn't parallelism here, and the example is trivial 2+2=4)
Option1A = OK (but the example is trivial 2+2=4)
Option1B = OK (but the example is trivial 2+2=4)
Can you please help me? Any advice wil be really useful....
Thanks
