Question: How to set up the the output format of graphs?
Hi:
 I use the following codes:
with(GraphTheory):
Graphs_data3:=[NonIsomorphicGraphs(6,restrictto =[connected], output
= graphs, outputform =graph)]:
Diameter2_select:=select[flatten](t->Diameter(t)=2,Graphs_data3):
map(DrawGraph,Diameter2_select);
nops(Diameter2_select);
Since  59 graphs are not many, so,I want to display  it. But the list show that
[Length of output exceeds limit of 1000000]`
How do I do?
If I use DrawGraph(Diameter2_select), the output is to large, and it is  not convenient to print it out .
