Question: Bug When Using IntegrationTools[Change] With Assumptions
Good day,
I was recently using Maple 2019 for work on a project, and ran into an error. This error (which will be copied and pasted below for others to test) occurs when making assumptions across multiple lines (whether using the additionally function or not) while using IntegrationTools[Change]. It seems that, if during the process a variable that was within both the assumptions is subtracted from itself, the subtraction fails to happen and leaves what effectively equals 0 in the workings, making further workings impossible.
I'm wondering if anyone else is able to reproduce this error? I know the fix for it is to not disjoint the assumptions, but I am curious if others can easily reproduce it or if others have experiences with it!
As promised, below you will find my workings in order to reproduce this error!
Base Error:
assume(a>0,b>0,b>a,c>0,t>0);
interface(showassumed=0);
F := Int(sqrt(d-a*c^2*t),d=0...infinity);
assume(b>a);
IntegrationTools[Change](F,-a*t*c^2+d=-y,y)
Simple Fix:
Error Without Interface Change:
assume(a>0,b>a,c>0,t>0);
assume(b>a);
Error When Using Additionally:
additionally(b>a);
