Question: question on simplifying with assumptions, using "and" vs ","
I do not understand why Maple can simplify this expression below when told that n is integer and also positive using a "," to separate the assumptions, but does simpify the same expression when using "and" to build the assumptions.
Here is an example
result:=int(x*cos(n*Pi/5*x),x=0..5)
simplify(result) assuming n::integer and n>0
But this works
simplify(result) assuming n::integer, n>0
What are the semantic differences between writing assuming "n::integer and n>0" and "n::integer,n>0" ? I thought these would be the same, but clearly they are not.
Maple 2019.1 on windows.
