Question: How to extract data from string tools output?
I want to evaluate a function of two variables at different values for these variables and collect the outputs in a matrix form. This is my best attempt at figuring it out -- using the string tools to evaluate a matrix at multiple values and spit out data. How can give each output labeled uniquely (not each line labeled A, but A,B,C... for n number of lines)? And How can I take the inner brackets out of the sequence output, to make each row of output data an array? Then I could refer to each data point individually with A[1],A[2],...,B[1],B[2],..., etc.
Please let me know if there is a better way to do this! Thank you, Jeremy
Also here is my code copied in text format for reference:
Zres:=5;
data:=[];
M:=Matrix(eval~(z*x,z=~[seq(n,n=1..Zres)]));
Array(eval~(z*x,z=~[seq(n,n=1..Zres)]));
with(LinearAlgebra):
for x from 1 to 5 by 0.5 do A:=[((op(data),seq(Column(M,n),n=1..Zres)))] od;
