Question: Parsing mistake in MAPLE
In equation(19), the value for F = 14.616.. is wrong. It was produced by a bult execution of the whole program. However, executing only equation(19) in one step results in the correct answer F=24.665. The values for SSE,SSR, which are 1 x 1 matrices, are correct. Indices(1x1) provide access to the elements as constants so that arithmetic operations can be performed.
The correct result follows an execution at eqn(19) as a stand alone. An incorrect result follows execution of the entire program.
  restart:
interface(rtablesize = 50); with(LinearAlgebra); with(plots); with(Statistics); with(ArrayTools);
Y := Matrix(12, 1, [2, 3, 2, 7, 6, 8, 10, 7, 8, 12, 11, 14]); n := ArrayNumElems(Y);
This is the data, with n rows and one column.
                                [2 ]
                                [3 ]
                                [2 ]
                                [7 ]
                                [6 ]
                                [8 ]
                           Y := [  ]
                                [10]
                                [7 ]
                                [8 ]
                                [12]
                                [11]
                                [14]
                            n := 12
type(Y, Matrix);
                              true
X := Matrix(12, 3, [1, 0, 2, 1, 2, 6, 1, 2, 7, 1, 2, 5, 1, 4, 9, 1, 4, 8, 1, 4, 7, 1, 6, 10, 1, 6, 11, 1, 6, 9, 1, 8, 15, 1, 8, 13]); k := NumElems(X)/n;
                             [1  0  2 ]
                             [1  2  6 ]
                             [1  2  7 ]
                             [1  2  5 ]
                             [1  4  9 ]
                             [1  4  8 ]
                        X := [        ]
                             [1  4  7 ]
                             [1  6  10]
                             [1  6  11]
                             [1  6  9 ]
                             [1  8  15]
                             [1  8  13]
                             k := 3
Xprimed := Transpose(X);
        Calculate Multiple Linear Regression in x1, and x2
                 [1  1  1  1  1  1  1  1   1   1  1   1 ]
      Xprimed := [0  2  2  2  4  4  4  6   6   6  8   8 ]
                 [2  6  7  5  9  8  7  10  11  9  15  13]
XprimedX := Xprimed . X;
                              [12   52   102 ]
                  XprimedX := [52   296  536 ]
                              [102  536  1004]
XprimedXinverse := MatrixInverse(XprimedX);
                      [   309          77              145 ]
                      [   ---          ---      uminus0--- ]
                      [   317          317             634 ]
                      [    77          411             141 ]
   XprimedXinverse := [   ---         ----      uminus0----]
                      [   317         2536             1268]
                      [       145         141       53     ]
                      [uminus0---  uminus0----      ---    ]
                      [       634         1268      634    ]
XprimedY := Xprimed . Y;
                                   [90 ]
                       XprimedY := [482]
                                   [872]
Betahat := XprimedXinverse . XprimedY;
                               [   1704   ]
                               [   317    ]
                               [   3819   ]
                    Betahat := [   ----   ]
                               [   1268   ]
                               [       815]
                               [uminus0---]
                               [       634]
Betahat := convert(Betahat, float);
                          [    5.375394322     ]
               Betahat := [    3.011829653     ]
                          [&uminus0;1.285488959]
 We choose the Null Hypothesis that Y= β0+Β1*x1+Β2*x2+ϵ .
Performing multiple linear regression leads to the best fit linear equation:
  Y= 5.38+3.01*x1-1.29x2
fit := plot3d(5.38+3.01*X1-1.29*X2, X1 = 0 .. 8, X2 = 2 .. 15);
data := pointplot3d({[0, 2, 2], [2, 5, 7], [2, 6, 3], [2, 7, 2], [4, 7, 10], [4, 8, 8], [4, 9, 6], [6, 9, 12], [6, 10, 7], [6, 11, 8], [8, 13, 14], [8, 15, 11]}, axes = normal, color = red, symbol = soliddiamond, symbolsize = 40, scaling = unconstrained, title = `\` Data vs Best Fit ' `);
display({data, fit});
        Comparison of Data and Best Fit
Yprimed := Transpose(Y); YprimedY := Yprimed . Y; BetahatPrime := Transpose(Betahat);
      Yprimed := [2  3  2  7  6  8  10  7  8  12  11  14]
                       YprimedY := [840]
BetahatPrime := [5.375394322  3.011829653  &uminus0;1.285488959]
SSE := YprimedY-BetahatPrime . XprimedY; SampleVariance := (YprimedY-BetahatPrime . XprimedY)/(n-k-1);
                   SSE := [25.4589905220000]
              SampleVariance := [3.18237381525000]
SSE (below) is a 1x1 vector which has been changed into a constant                                                  Covariance of β
`covβ` := Typesetting[delayDotProduct](SSE(1, 1), XprimedXinverse, true);
covβ := [
  [24.8164923384795, 6.18404501638486, &uminus0;5.82263978815458],
  [6.18404501638486, 4.12604302229574, &uminus0;2.83100762113723],
  [&uminus0;5.82263978815458, &uminus0;2.83100762113723,
  2.12827523291167]]
SSR := Transpose(Betahat) . Transpose(X) . Y-n*MeanY(1, 1)^2;
                   SSR := [139.541009478000]
SST := SSR+SSE; F := SSR(1, 1)*(n-k-1)/(k*SSE);
F is found in textbook eqn (8.5)
                         SST := [165.]
                    F := [14.6160295824160]
RsquaredNonCentered := Determinant(SSR)/Determinant(SST); R := sqrt(%);
            RsquaredNonCentered := 0.845703087745454
                     R := 0.919621165342259
MeanY := Mean(Y);
                  MeanY := [7.50000000000000]
RsquaredCentered := `~`[`.`](Transpose(Betahat) . Transpose(X) . Y-n*MeanY(1, 1)^2, 1/(Yprimed . Y-n*MeanY(1, 1)^2));
            RsquaredCentered := [0.845703087745454]
        We note the same value for R -data not centered, and that for R-data which is centered.
Transpose(Betahat) . Transpose(X) . Y; MeanY(1, 1)^2; Yprimed . Y;
# Compare SSR, Mean of Y (data), and SST to results in the book.
                       [814.541009478000]
                        56.2500000000000
                             [840]
                                                     Table 8.2 on Page 189 of textbook
                                    ANOVA for Overall Regression Test for Data in Table 7.1
________________________________________________________________________________________________________
 Source           df                                                   SS                                                        MS                                                 F
 _________________________________________________________________________________________________________
 Include β1    2                                        139.5410                                    69.7705                                24.665
Error           9                                          25.4590                                      2.8288
         Total                                             165.0000
and from calculations using the defining equations in step(12) through step(13) and summarized in Step(19):
F := SSR(1, 1)*(n-k-1)/(k*SSE(1, 1)); SSE, SSR, SSR+SSE; Total := Yprimed . Y-n*MeanY(1, 1)^2;
                     F := 14.6160295824160
         [25.4589905220000], [139.541009478000], [165.]
                        Total := [165.]
