Question: Chebyshev series in different intervals
My question is mathematical in nature, so it might be a little out of place but I though I would give it a shot.
You have a series of chebyshev coefficients in two connecting subdomains lets say S1 = [0,0.5] and S2=[0.5,1]. So far you are still in the spectral space. If you want to compute the solution in real space you can sum the coefficients with the Chebyshev polynomials.
Now imagine you change the interval to S1 = [0,0.6] and S2 = [0.6,1]. Is there a way to manipulate the Chebyshev coefficients from both initial subdomains to create a new set of Chebyshev coefficients that fit the solution in the new subdomains.
The brute force method would be to create the real solution of Chebyshev polynomials and then use that to form a new set of Chebyshev coefficients. Or you can use Clenshaw to compute the solution at several points, and then use the points to create new Chebyshev coefficients.
But what if we can stay in spectral space and create the new chebyshev coefficients. Is that possible? If so, how?
