Question: Problem using units with differential equation problem
Hi
I am doing a differential equation problem and decided to add units. However, when using dsolve i get the error:
"Error, (in dsolve) the units `s` and `1` have incompatible dimensions"
Can some of you experts see where i am wrong?
restart
with(Units[Standard])
assume(t >= 0*Unit('s'))
Acceleration := diff(h(t), t, t) = g-b*(diff(h(t), t))/mass
diff(diff(h(t), t), t) = g-b*(diff(h(t), t))/mass
Source: https://adventure.howstuffworks.com/skydiving1.htm
b := piecewise(`and`(t >= 0, t < T), b__1, `and`(t >= T, t < infinity), 7*b__1)
piecewise(t < T, b__1, T <= t, 7*b__1)
T := 60*Unit('s')
60*Units:-Unit(s)
(3)
mass := 80*Unit('kg')
80*Units:-Unit(kg)
(4)
b__1 := 13*Unit('kg'/'s')
13*Units:-Unit(kg/s)
(5)
g := -9.81*Unit('m'/'s'^2)
-9.81*Units:-Unit(m/s^2)
(6)
IC := h(0) = 4000, (D(h))(0) = 0
(7)
solution := dsolve({IC, Acceleration}, h(t))
H := eval(h(t), solution)
Error, invalid input: eval received solution, which is not valid for its 2nd argument, eqns
fsolve(H = 0, t, 0 .. infinity)
Error, (in fsolve) H is in the equation, and is not solved for
plot(H, t = 0 .. 150, y = 0 .. 4100, axis[2] = [gridlines = 30], axis[1] = [gridlines = 20], labels = ["t [s]", "h(t) [m]"], labelfont = ["Times", 15], color = "red", size = [1000, 1000])
Warning, expecting only range variable t in expression H to be plotted but found name H
Download Problem_1_test.mw
