Question: How to create a procedure that only uses x-points from a given set of coordinate data?
Say you have your data, a list of coordinates as,
d1 := [[3, 11], [4, 6], [5, 8]]
Where the goal here is to take the x-coordinate, subtract that by two, then add all the subtracted coordinates together, basically,
(3-2)+(4-2)+(5-2) = 6
I would like to write a procedure to do this, my template done to the best of my maple knowledge below:
f2 :=proc(dat::list)
for i from 1 to nops(dat) do
val1:={{ PULL data[i,1]}}
sub2 :=val1-2
{{add sub2 to new 1 D array}}
{{sum array}}
end proc
The '{{ }}' brackets indicate that I have no idea how to do that function. Basically, I need to pull each x-element, subtract it by 2, add to a new list, and sum the list.
I would be grateful for any help, thanks!
