Question: Simplification of an expression
Dear Users!
Hope you would be fine with everything. I want the simpliest for of the following expression in two step:
diff(U(X, Y, Z, tau), tau)+U(X, Y, Z, tau)*(diff(U(X, Y, Z, tau), X))+V(X, Y, Z, tau)*(diff(U(X, Y, Z, tau), Y))+W(X, Y, Z, tau)*(diff(U(X, Y, Z, tau), Z))+u[delta]*lambda[1]*(diff(U(X, Y, Z, tau), tau, tau))/L[delta]+u[delta]*lambda[1]*(diff(U(X, Y, Z, tau), tau))*(diff(U(X, Y, Z, tau), X))/L[delta]+u[delta]*lambda[1]*U(X, Y, Z, tau)*(diff(U(X, Y, Z, tau), tau, X))/L[delta]+u[delta]*lambda[1]*(diff(V(X, Y, Z, tau), tau))*(diff(U(X, Y, Z, tau), Y))/L[delta]+u[delta]*lambda[1]*V(X, Y, Z, tau)*(diff(U(X, Y, Z, tau), tau, Y))/L[delta]+u[delta]*lambda[1]*(diff(W(X, Y, Z, tau), tau))*(diff(U(X, Y, Z, tau), Z))/L[delta]+u[delta]*lambda[1]*W(X, Y, Z, tau)*(diff(U(X, Y, Z, tau), tau, Z))/L[delta];
Step 1:
diff(U(X, Y, Z, tau), tau)+U(X, Y, Z, tau)*(diff(U(X, Y, Z, tau), X))+V(X, Y, Z, tau)*(diff(U(X, Y, Z, tau), Y))+W(X, Y, Z, tau)*(diff(U(X, Y, Z, tau), Z))+u[delta]*lambda[1]*(diff(diff(U(X, Y, Z, tau), tau)+U(X, Y, Z, tau)*(diff(U(X, Y, Z, tau), X))+V(X, Y, Z, tau)*(diff(U(X, Y, Z, tau), Y))+W(X, Y, Z, tau)*(diff(U(X, Y, Z, tau), Z)), tau))/L[delta];
Step 2: (final form I need)
(1+(u[delta] lambda[1])/(L[delta]) (∂)/(∂tau)) ((∂)/(∂tau) U(X,Y,Z,tau)+U(X,Y,Z,tau) ((∂)/(∂X) U(X,Y,Z,tau))+V(X,Y,Z,tau) ((∂)/(∂Y) U(X,Y,Z,tau))+W(X,Y,Z,tau) ((∂)/(∂Z) U(X,Y,Z,tau)));
I'm waiting for your response.
Special request:
@acer @Carl Love @Kitonum @Preben Alsholm
