Question: Collocating a vector
Hi User!
Hope you would be fine with everything. I have a vector "POL" of M dimension obatined for the following expression
restart; with(LinearAlgebra); nu := 1; M := 3;
for k while k <= M do
Poly[k] := simplify(sum(x^i*GAMMA(nu+1)/(factorial(i)*GAMMA(2*nu)), i = 0 .. k-1))
POL := `<,>`(seq(Poly[k], k = 1 .. M))
and I want to construct a matrix of M by M by collocating it on the points x=i/(M-1) for i=0,1,2,...,M-1 like the following way,
For M=3 I need
Matrix(3, 3, {(1, 1) = Poly[1](0), (1, 2) = Poly[1](1/2), (1, 3) = Poly[1](1), (2, 1) = Poly[2](0), (2, 2) = Poly[2](1/2), (2, 3) = Poly[2](1), (3, 1) = Poly[3](0), (3, 2) = Poly[3](1/2), (3, 3) = Poly[3](1)});
For M=4 I need
Matrix(4, 4, {(1, 1) = Poly[1](0), (1, 2) = Poly[1](1/3), (1, 3) = Poly[1](2/3), (1, 4) = Poly[1](1), (2, 1) = Poly[2](0), (2, 2) = Poly[2](1/3), (2, 3) = Poly[2](2/3), (2, 4) = Poly[2](1), (3, 1) = Poly[3](0), (3, 2) = Poly[3](1/3), (3, 3) = Poly[3](2/3), (3, 4) = Poly[3](1), (4, 1) = Poly[4](0), (4, 2) = Poly[4](1/3), (4, 3) = Poly[4](2/3), (4, 4) = Poly[4](1)})
and general form is like this
[[[Poly[1](0/(M-1)),Poly[1](1/(M-1)),Poly[1]((2)/(M-2)),...,Poly[1]((M-1)/(M-1))],[Poly[2](0/(M-1)),Poly[2]((1)/(M-1)),Poly[2]((2)/(M-1)),...,Poly[2]((M-1)/(M-1))],[Poly[3]((0)/(M-1)),Poly[3]((1)/(M-1)),Poly[3]((2)/(M-1)),...,Poly[3]((M-1)/(M-1))],[...,...,...,...,...],[Poly[M]((0)/(M-1)),Poly[M]((1)/(M-1)),Poly[M]((2)/(M-1)),...,Poly[M]((M-1)/(M-1))]]];
Another problem is I want to define a vector of M dimension using a function f(x)=sin(x) and two points a=1, b=2 like the following way,
Vec:=[[[a],[f((1)/(M-1))],[f((2)/(M-1))],[f((3)/(M-1))],[...],[f((M-1)/(M-1))],[b]]]
Please fix my problem. I'm waiting for your kind response.
Special request @acer @acer @Carl Love @Kitonum @Preben Alsholm
