Question: Implicitplot returns nothing
I'm trying to graph the solution to:
[7.72-7.72*B]*[-7.717267500*a] = 662204.4444*B^2
with a as the independent variable (X-Axis) and B as the dependant variable (Y-Axis). I've been using the command:
implicitplot([7.72-7.72*B]*[-7.717267500*a] = 662204.4444*B^2, a = 10 .. 15000, B = 0.1e-1 .. 1)
I dont get any errors, but the graph is ust a blank graph that is -10..10 for both axis (at least they are labelled correctly)
Any help as to how to solve this woud be greatly apprecated (either fixing syntax or recommending another command).
Note: These ranges are correct....a will be something between 0 and 20,000 and B will be between 0 and 1
Thank you! - Bob
