Question: how to display multiple plots in row or column such that no space is wasted?
When I use something like plots[display](Array([p1,p2]));  And the plots p1,p2 have been resized before to be small, there is lots of wasted empty space in the final result. I have to manually adjust the size of each Array entry with the mouse to make the fit better. But this solution is not practical.
Is there an option to do this automatically? Here is an example
p1:=plot(sin(x), x=-Pi..Pi, size=[300,300]):
p2:=plot(cos(x), x=-Pi..Pi, size=[300,300]):
plots[display](Array([p1,p2]));   #one option
plots[display](Vector[row]([p1,p2])); #another option
Manually, using the mouse, I can, after some adjustments and trrial and errors, get the final result such that the wasted space is removed.
I am asking, becuase if I want to save/export the above final plot as PDF to include in a Latex document, it will look bad with that wasted space there.
How to do this adjustment using code?
In Mathematica for example, this is done using Grid and the Spacing option. I could not find something similar in Maple but I could have overlooked it.
