Question: seems like bug in Maple mint
This proc is valid, yet Maple mint thinks there is syntax error
foo:= proc(x)
local z := "";
    if not x in ["A","B"] then
        return;
    fi;
    z:=cat("A
            B");
mint t.mpl gives
on line     7:     z:=cat("A
                          ^ Syntax error
A "then" was found without a previous matching "if".
An "end" may be needed to close the "in" construct from line 3.
But these two below procs below it gives no syntax error
foo:= proc(x)
local z := "";
        return;
    fi;
And
foo:= proc(x)
local z := "";
    z:=cat("A
            B");
No syntax error on either one. the syntax error only shows up when combining them.
What does if not x in ["A","B"] then  have to do with the cat  below it? And why when they are combined, the syntax error shows?
I know of workaround, such as changing the cat to  z:=cat("A\nB");     or keep the strings on two lines, but do it like this
    z:=cat("A\n
           B");
Or write it like this
   z:=cat("A "
           "B");
But none of these changes were needed before adding the not x in ["A","B"]  before.
Is this a bug in mint? Is there a work around so the first example above still works using
    z:=cat("A
            B");
