Question: how to store Objects in an Array?
I wanted to create an Array() to store only objects of specific type in it.
Array() supports the datatype=value  telling it the type of elements to store. But when I try to create an Array() using datatype of the class, it fails. I must be doing something wrong. Here is an example
module solution_class()
      option object;
      local sol::anything;
end module;
sol:=Object(solution_class); #create an object
Now the following works:
A:=Array();
A(1):=sol;
But I wanted to do
A:=Array(datatype=solution_class);
A(1) := sol;
 Error, unable to store '0' when datatype=module solution_class () local sol::anything; option object; end module
Help says
And this is the case here, because type(sol,solution_class)  gives true
So 'solution_class' is valid type name.
Where is my error?
