Question: is this expected name resolution issue?
If one refers to a name in Maple, I thought it will look at the global context to find it. So when one does latex(....) then this is assumed to be the system latex command. No need to do :-latex()
But if there is local variable in Object class called latex, why then is object:-latex gets confused with global Maple command latex()?  Here is an example
module ode_class()
      option object;
      local latex::strring :="";
      export init::static:=proc(o::ode_class)
        o:-latex:= latex(1/2,output=string);
end module:
my_ode:=Object(ode_class):
Error, static procedure `ode_class:-init` refers to non-static local or export `ode_class:-latex::strring` in surrounding scope
ofcourse easy to fix, I just replace the RHS latex(1/2,output=string);  with :-latex(1/2,output=string);
But my question why is object:-latex := latex(...)  makes Maple think the latex in the RHS is the variable name in the class, when it does not have the  object:- prefix?  Is this expected  behaviour in Maple?
But now I am starting to worry that each maple command/function/name used inside the Object needs  :- added to it, just in case of a current or future name conflict with local object variables names.
