Question: how to obtain conditions used by coulditbe ?
From help, it says
coulditbe routine returns true if there is a possible value of x1 that satisfies prop1
my question is, how to find out this condition/possible values that Maple found?  This infomration is very useful, but now I do not see how to obtain it. All what coulditbe retuirn is true or false.
Context of why I am asking:  Sometimes odetest do not verify its own solutions. And coulditbe can help in finding under what conditions the solution can satisfy the ode. Here is an example
ode:=diff(y(x),x) = abs(y(x))+1;
solExplicit:=dsolve(ode);
offset := odetest~([solExplicit],ode)
gives
[exp(-x)/_C1 - abs((-exp(-x) + _C1)/_C1) - 1, exp(x)*_C1 - abs(exp(x)*_C1 - 1) - 1]
Both solution fail odetest.
coulditbe~(offset,0)
gives true
So there are assumptions/conditions which makes the solution satisfy the ODE. In this case, by inspection one can see what these conditions are. They are, for one solution:
(-exp(-x) + _C1)/_C1  >0
and for the other, the condition is
exp(x)*_C1 - 1 >0
Under these assumptions, odetest would have given 0 for each odetest.
And it is this information I wanted to obtain automatically from coulditbe.
In Mathematica, Reduce is used for this. Reduce gives conditions under which something is satisfied. For example,
Reduce[ C[1] Exp[x] - Abs[C[1] Exp[x] - 1] - 1 == 0, {x, C[1]}, Reals]
Gives
C[1] >= Exp[-x]
While the above in  Maple
coulditbe( C[1]*exp(x)- abs( C[1]*exp(x)-1)-1 = 0)
gives true  only, but without the important information, true under what conditions.
Is there a different command in Maple which could give this information?
