Question: How to Build a Package Module from Collected Pieces while Using Shared Helper Procedures
I am creating a largish package (i.e., for use by others with the “with” command).
Most of the exported procedures have some derivations associated with the code.  This is at least a partial reason for using Maple.  So, I had organized a worksheet so that each exported procedure has its own section that included pre-coding derivations, the procedure, and some post-coding validation of the code (serious testing is done elsewhere).  At the end of the worksheet I had a section that built the module and saved it to the appropriate library.  If I execute the worksheet it runs through everything and builds a new version of the library containing the package.
Getting these exported procedures to bind to a local helper procedure that is shared among several exported procedures was a bit tricky.  The way I ended up doing it is illustrated in the attached worksheet.
From a life cycle perspective is there a better way to think about this?
restart
with(InertForm)
[Display, FromMathContainer, MakeInert, NoSimpl, Parse, SameStructure, ToMathContainer, ToMathML, Typeset, Value]
DistWorkSheet := proc (A, B) F(A[1]-B[1])+F(A[2]-B[2]) end proc
"Test:=module()"
"  export Dist"
_local(Sqr)
"  option package;"
NULL
Sqr := proc (A) A*A end proc
Dist := eval(subs(F = eval(Sqr), eval(DistWorkSheet)))
"end module"
_m2052587788544
(3)
eval(Test:-Dist)
proc (A, B) (proc (A) A*A end proc)(A[1]-B[1])+(proc (A) A*A end proc)(A[2]-B[2]) end proc
(4)
Test:-Dist([0, 0], [1, 1])
2
(5)
NULL
Download PackageBuild.mw
