Question: strange result from select.
I can't understand why select(has,3*C,x) returns 1  and select(has,3+C,x) returns 0
I was expecting to get NULL or {}. But when doing select(has,[3*C],x) and select(has,[3+C],x)  now both return [ ] as expected
Where did 1 and 0 come from in the above examples? I looked at help page, but do not see it.
select(has,3*C,x)
select(has,3+C,x)
or the same:
select(z->has(z,x),3*C);
select(z->has(z,x),3+C)
The select function selects the operands of the expression e which satisfy
the Boolean-valued procedure f, and creates a new object of the same type
as e. Those operands for which f does not return true are discarded in the
newly created object.
The above is the same as if one typed
select(x->false,3+C);
       0
select(x->false,3*C);
       1
