Question: Assumptions in pdsolve
How can I use assmptions in partial differential equations?
For example consider the following differential equation
pde:=diff(u(x,t),t)+alpha*diff(u(x,t),x)=0
sol:=pdsolve(pde,build) assuming alpha=0
This gives me the same solution if alpha!=0
I also tried this
assume(alpha=0)
sol=pdsolve(pde,build)
I again got the same result as if alpha!=0. Except this time there was a tilde on the right side of alpha (to my knowledge that means there are assumptions on alpha)
How do you apply assumptions in PDEs?
