Question: Try Installing old package for Maple 6 : with(lamp)
How to install this old package for Maple 6 , should be trivial but turns te be out a puzzle with no result so far.
### This is the Maple initialization file created for use with the
### LAMP modules. For Maple 6 in Windows 95, 98, 2000, or NT, this file
### should be installed in the folder
###        C:\Program Files\Maple 6\BIN.WNT
### The last three letters, WNT, may vary with the version of Windows.
### The following lines set up libname, so Maple knows to look in the
### proper folder to find the Lamp library. If you did not put the
### Lamplib folder in C:\lamp6\lamplib, you must edit the first line.
lamppath := "C:\\lamp6\\lamplib\\":
libname := `lamppath`, libname:
### The following line enables one to use the command read(lampstart)
### to establish the Lamp environment. It is optional.
lampstart := cat(lamppath,"lamp.txt"):
