Question: How to find symbolic extreme values under constrained equality ?
Unfortunately,  Optimization:-Maximize command in following example returns a not precise result (I use Maple 2020).
restart:
s1:= Optimization:-Maximize((x-2*y)/(5*x^2-2*x*y+2*y^2), {2*x^2 - y^2 + x*y=1})
Maple is running the following results:
I read help of  Maximize, It seems to be using only numerical methods .
The Minimize and Maximize commands use various methods implemented in a built-in library provided by the Numerical Algorithms Group (NAG).
Can't Maple find a symbolic solution for extreme values under such constrained inequality or equality conditions?
Ps:
For the correct  symbolic  solution, we can try to  use Mathematica 12.
Maximize[{(x - 2*y)/(5*x^2 - 2*x*y + 2*y^2),
  2*x^2 - y^2 + x*y == 1}, {x, y}]
  We can compare numerical sizes of Optimal solution between maple and mathematica.
Digits:=20;
sqrt(2.)/4.
Another Problem:
If I accept numerical solutions of maple ,how do I estimate errors without knowing the exact solution ?
