Question: Store data between sessions ?
I just wonder how it is possible to store data between sessions. What I found out is that if a matrix is connected with a datatable, the matrix data is stored. If it is not connected with a datatable, it is not.
In the attached example there are 2 matrices. If you run the worksheet, both variables are defined as visible in the variable overview.
After reopening without running the worksheet, just the variable connected with a datatable is.
Any ideas how to also get the second variable stored between sessions (obviously not with the same method as used for a)?
storetable.mw
