Question: Get only the result in allvalues
I'm writing a script that solves a system of equations. I have 2 unknows that I seem to get when using "explicit" et "allvalues". The result I get from "allvalues" is in this form. My question is : how can I get just the result, without the "lambda22=" (other than copy/paste of course ;))?
lambda22 = sqrt(10)*sqrt(lambda11*(pi*lambda11 + 90))/(30*lambda11)
My code is
kappa:=30:
tensF:=Matrix([[lambda11,0,0],[0,lambda22,0],[0,0,lambda22]]):
tensFbar:=Matrix([[lambda11bar,0,0],[0,1/sqrt(lambda11bar),0],[0,0,1/sqrt(lambda11bar)]]):
tensBbar:=Multiply(tensFbar,Transpose(tensFbar)):
tensPK:=Matrix([[pi,0,0],[0,0,0],[0,0,0]]):
tensPK1:=Multiply(Transpose(MatrixInverse(tensF)),(2/Determinant(tensF))*a*(tensBbar-(1/3)*Trace(tensBbar)*Matrix(3,shape=identity))+kappa*(Determinant(tensF)-1)*Matrix(3,shape=identity)):
eq1:=tensPK[1,1]=tensPK1[1,1]:
eq2:=tensPK[2,2]=tensPK1[2,2]:
sys:={eq1,eq2}:
sol1:=solve( sys, {lambda11bar,lambda22},explicit):
allvalues(sol1[1][1]);
allvalues(sol1[1][2]);
This should be something easy to get but I don't find the method anywhere.
Many thanks in advance if you know how to do this,
Manon
