Question: Remove extra whitespace from 3d plot
How can I remove the extra whitespace around a 3D plot and also scale it so it takes up quite a bit of the window so I can see more detail?
If I use a density plot then I can set the size using
_SP := proc(P,sz::[posint,posint] := [1200,500])
  op(0,P)(remove(type,[op(P)],'specfunc(ROOT)')[],
          ROOT(BOUNDS_X(0),BOUNDS_Y(0),
               BOUNDS_WIDTH(sz[1]),BOUNDS_HEIGHT(sz[2]))):
to get exactly what I want. With 3D plot there is a lot of whitespace. I'd rather use plot3d since it is more confirgurable but I need to be able to remove all that additional whitespace(which I guess has to do with rotation in 3D, but here I'm not rotating it, although I might want to in some cases).
