Question: why getting error on some Physics:-Latex setting after adding powersoftrigonometricfunctions= computernotation?
After I just updated to Physics 871, my main worksheet which allready has for long time now:
Physics:-Latex:-UseColor := false;
Physics:-Latex:-UseImaginaryUnit:=i;
Now I get
The reason I use Physics:-Latex:-UseImaginaryUnit:=i; is to make the Latex use for complex number in Latex instead of I
What is now the correct way to use these settings with the new Physics update? if I do not use them, then compelx I  will still show as I whcih I do not want. I want lower case i
I could add interface(imaginaryunit=i); in place of Physics:-Latex:-UseImaginaryUnit:=i; and that work for the latex, making the Latex generate i. But this solution now makes the User interface no longer accept I  as complex number any more and must be typed as lower case, which is not what I want.
That is why I was using Physics:-Latex:-UseImaginaryUnit:=i; This keeps the user interface complex number as Uppercase, but let the latex generated be lower case.
I feel I am doing something wrong, but do not see it. Made sure I use Physics:-Latex on everything now.
Please see below 2 worksheets. One using the 871 version and one using 865 version.
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 871 and is the same as the version installed in this computer, created 2020, November 14, 14:16 hours Pacific Time.`
Physics:-Latex:-Settings()
[invisibletimes = ` `, powersoftrigonometricfunctions = mixed, usecolor = true, useimaginaryunit = I, useinputlineprompt = true, userestrictedinputtranslation = false, usespecialfunctionrules = true, usetypesettingcurrentsettings = false]
Error, attempting to assign to `Physics:-Latex:-UseColor` which is protected
Error, attempting to assign to `Physics:-Latex:-UseImaginaryUnit` which is protected
Physics:-Latex(I)
I
Download latex_871.mw
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 871. The version installed in this computer is 865 created 2020, November 11, 8:43 hours Pacific Time, found in the directory C:\Users\me\maple\toolbox\2020\Physics Updates\lib\`
usecolor = true, useimaginaryunit = I, useinvisibletimes = ` `, useinputlineprompt = true, userestrictedinputtranslation = false, usespecialfunctionrules = true, usetypesettingcurrentsettings = false
Physics:-Latex(I);
false
i
i
Download latex_865.mw
