Question: Some Symbolic Calculations and Defining a procedure for a new integral operation
EDIT TIME: 14:30 CET
where P(1) and P(2) are NxN matrix functions.
My trial code for STEP 0
 alpha times integral w.r.t. x
 Int_x__alpha:=proc(term,alpha):
 return
select(has,term,x).P(alpha)^T.remove(has,term,x)
 alpha times integral w.r.t. t
Int_t__alpha:=proc(term,alpha):   #alpha times integral w.r.t. t
 return
remove(has,term,t).P(alpha).select(has,term,t)
when I run the last procedure for the testing
 Int_t__alpha(Psi(x)^T.C. Psi(t),2);
I get
But it must be
Because the multiplication is not commutative in Matrices. So, the last procedure must be corrected.
DETAILS for the procedures:
MAIN QUESTION:
Suppose that we have a PDE as follows
                                             ...(3)
subject to appropriate Initial and Boundary conditions.
STEP 1
  • Find the highest derivative w.r.t. x and w.r.t. t. Then, Let the trial function be the summation derivative of these highest derivatives. I mean
Trial Function:                                           ...(4)
where Psi(x), Psi(t) are Nx1 vectors and C is a NxN matrix.
I can't write a maple code for selecting the trial function.  May be you can.
trial_function:=diff(u(x,t),x,t)=Psi(x)^T.C. Psi(t);
# I deliberately used ^T instead of ^+ for Transpose.
# If I use ^+, the transpose sign doesn't appear in 2d output. May be you have an other idea.
STEP 2
  • Integrate the Eq.4  w.r.t. t from 0 to t, we have
STEP2:=int(  lhs(trial_function) ,t=0..t)=Int_t__alpha(rhs(trial_function),1);
The code must be improved. Firstly, substitute t=s in lhs(trial_function) and then integrate s=0..t
STEP 3
int(lhs(STEP2),x=0..x)= Int_x__alpha(rhs(STEP2),1);
STEP 4
  • Integrate Eq.4 w.r.t x
STEP 5
  • Substitute Eq. (5), Eq. (6), Eq. (7) to Eq. (3),
  • I mean substituting  u_x(x,t), u_t(x,t), u(x,t) to PDE.
STEP 6
DOWNLOAD ALL MAPLE CODE: all_code.mw
