Question: write a procedure in maple
 1. Consider this code line: > a := b; b := c; c := matrix([[1, 2, 3], [3, 4, 5]]);
    • if you ask Maple to return the values assigned to a, b and c, which values will be printed?
    • Are these values the ones you would expect? Why? Which kind of evaluation rule is utilized by Maple to return these values?
   • Show the single steps of the evaluation process and briefly explain the outcome of each evaluation step (hint: use eval (a, 1/2/3), to return each evaluation step).
   • How can you “force” Maple to return the “expected” values for a, b and c? • Extract the first row of the matrix in such a way to have [1, 2, 3] as output. Hint: use the command row/Row and its right syntax (it needs two arguments: the name of the matrix and the number of the row to extract). Be careful to load the linalg/LinearAlgebra package before using the command. Instruction: apply the row/Row command to a, b and c.
  • Can you explain what Maple does in the previous step? Can you explain, in other words, why you get the expected outcome? Hint: remember which are the “drivers” of the evaluation process in Maple (position of the assignment/level of evaluation; type of object / data-structure / datacontainer / procedures / local versus global variables / use of built-in commands, etc.).
