Question: question on setting type of parameter of proc
I'd like to define a proc, which takes first argument to be either an ode (i.e. type `=`) or set of ode's, or list of ode's.
However, I do not know how to tell Maple that the list or set, if that is the type, to be a list of `=` and no other type.
Here is what I tried to make it more clear
If I do this
interface(warnlevel=4);
kernelopts('assertlevel'=2):
foo:=proc(ode::{`=`, set,list},func::`function`,$)
   print("ode=",ode);
   print("func=",func);
Then Maple will check that the first argument is ANY one of `=`, set or list.
But does not check if the list or set contains only equations of type `=`.  So I am able to call the above like this
ode1:=diff(y(x),x)=1:
ode2:=diff(y(x),x)=x:
foo(ode1,y(x));  #this is OK
foo([ode1,a],y(x))  #this is wrong
Which is wrong, since `a` is not of type `=`.
Next I tried this (I also wanted to check that if first argument is list or set, that it is not empty, so added extra check)
                   And(set,satisfies(x-> (numelems(x)<>0 and type(x,`=`))  )),
                   And(list,satisfies(x-> (numelems(x)<>0 and type(x,`=`))  ))
                   func::`function`,$
  print("ode=",ode);
But the above gives an error
foo([ode1,a],y(x))
I also tried
                   And(set,satisfies(x-> type(x,`=`)  )),
                   And(list,satisfies(x-> type(x,`=`) ))
                   func::`function`,$
   print("ode=",ode);
Also gives erorr when called
foo([ode1,ode2],y(x))
Ofcourse, I can just leave the check as in first case above, and in the proc itself, do the check myself manually by going over each entry in the list or set to make sure each entry is of type `=`.
But I wanted Maple to do this work for me, if possible.
What is the correct syntax for doing so?
Maple 2020.2
