Question: Parallelize a double for-loop using Grid
Hi, I would like to parallelize the double for loop. I am computing pairwise SPolynomials like so
for i from 1 to n-1 do
for j from i+1 to ndo
spol:=Spol(poly[i],poly[j], tdeg(op(vars))):
od:
od:
I would like to parallelize this code, here is what I have done:
at_node:=proc(p1,p2,vars, polynomials)
spol:=SPolynomial(p1,p2,tdeg(op(vars))):
if NormalForm(spol, polynomials, tdeg(op(vars)))=0
return [1,0]:
fi:
Grid[Setup]("local", num_nodes=4):
Grid[Set](at_node): # below is the main loop that fails
for idx from 1 to n-1 do
out:=Grid[Seq](at_node(polynomials[idx], polynomials[j], vars, polynomials) j=idx+1, n):
od:
The loop above fails due to the error when calling normal form. It seems that the at_node function accepts an incorrect input for p1, a list of polynomials instead of a single polynomial. Is there a way to parallelize double for-loop with Grid like that? I am not sure where my error is.
