Question: problem using $include in module. export declaration unexpected outside module
This seems like a serious limitation of Maple module, unless I am missing something.
I am trying to refactor one of my module, putting some code in separate .mpl file, say B.mpl,  and then do, from the main module
   $include  "B.mpl";
 But Maple complain now that, since B.mpl has export in it, that I can't do that.
But the code inside B.mpl works fine if I copy it back and paste it inside the module, in the same location where the $include  "B.mpl";  is
Here is an example. (Since I can't use $include  "B.mpl";  in worksheet, Maple does not like it, I replaced it in this example by read "B.mpl";
(btw, both the syntax  module A()   and A:=module() seem to be equivalent), the problem shows up with either form)
I also tried with ";" and witout ";" at the end of the $include , it still gives same error.
currentdir("....."); #set directory to where the folder is
module A()
read "B.mpl";
 export foo:=proc()
  0;
end module;
Where the file B.mpl is
export boo:=proc()
return 0;
How is one supposed to refactor long file to separate files if can't leave export on those proc's?
If I put everything in one .mpl file, it works
module A()
#read "B.mpl";
export boo:=proc()  #this proc was in B.mpl
return 0;
 export foo:=proc()
  0;
end module;
I did more testing, and found that this seems to be an issue in Maple 2020.2. Because I just tried the same thing in Maple 2019 and it worked there ! i.e. no error.
Any one knows what is going on?
Maple 2020.2, Physics 884.   Windows 10.
Here is screen shot. Same code. Works OK in Maple 2019.2 but gives error in 2020.2
