Question: Regression in Latex between 897 and 905. Wrong Latex geneated
In Latex 897 correct Latex is generated for the following code. In 905, wrong Latex is generated. This is different from the other cases I posted about (links below) and new issue.
In 897, the Latex generated for this example compiles with no error
sol:=(Vector(2, [x__1(t),x__2(t)])) = (Vector(2, [2^(3/4)*3^(1/4)*(exp(2^(3/4)*3^(1/4)*t)*_C1-exp(-2^(3/4)*3^(1/4)*t)*_C2-sin(2^(3/4)*3^(1/4)*t)*_C3+cos(2^(3/4)*3^(1/4)*t)*_C4),2*6^(1/2)*(exp(2^(3/4)*3^(1/4)*t)*_C1+exp(-2^(3/4)*3^(1/4)*t)*_C2-sin(2^(3/4)*3^(1/4)*t)*_C4-cos(2^(3/4)*3^(1/4)*t)*_C3)]));
Latex(sol)
Now compiling the Latex gives
\documentclass[11pt]{article}
\usepackage{amsmath}
\usepackage{maplestd2e}
\begin{document}
\left[\begin{array}{c}x_{1} \! \left(t \right) \\x_{2} \! \left(t \right) \end{array}\right]
\left[\begin{array}{c}2^{\frac{3}{4}} 3^{\frac{1}{4}} \left({\mathrm e}^{2^{\frac{3}{4}} 3^{\frac{1}{4}} t} \mathit{\_C1} -{\mathrm e}^{-2^{\frac{3}{4}} 3^{\frac{1}{4}} t} \mathit{\_C2} -\sin \! \left(2^{\frac{3}{4}} 3^{\frac{1}{4}} t \right) \mathit{\_C3} +\cos \! \left(2^{\frac{3}{4}} 3^{\frac{1}{4}} t \right) \mathit{\_C4} \right) \\2 \sqrt{6}\, \left({\mathrm e}^{2^{\frac{3}{4}} 3^{\frac{1}{4}} t} \mathit{\_C1} +{\mathrm e}^{-2^{\frac{3}{4}} 3^{\frac{1}{4}} t} \mathit{\_C2} -\sin \! \left(2^{\frac{3}{4}} 3^{\frac{1}{4}} t \right) \mathit{\_C4} -\cos \! \left(2^{\frac{3}{4}} 3^{\frac{1}{4}} t \right) \mathit{\_C3} \right) \end{array}\right]
\end{document}
In 905
The Latex(sol) gives
\begin{document}
\left({\mathrm e}^{2^{\frac{3}{4}} 3^{\frac{1}{4}} t} \textit{\_C1} -{\mathrm e}^{-2^{\frac{3}{4}} 3^{\frac{1}{4}} t} \textit{\_C2} -
\sin \! \left(2^{\frac{3}{4}} 3^{\frac{1}{4}} t \right) \textit{\_C3} +\cos \! \left(2^{\frac{3}{4}} 3^{\frac{1}{4}} t \right) \textit{\_C4} \right)
 2 \sqrt{6}\,
\left({\mathrm e}^{2^{\frac{3}{4}} 3^{\frac{1}{4}} t} \textit{\_C1} +{\mathrm e}^{-2^{\frac{3}{4}} 3^{\frac{1}{4}} t} \textit{\_C2} -
\sin \! \left(2^{\frac{3}{4}} 3^{\frac{1}{4}} t \right) \textit{\_C4} -\cos \! \left(2^{\frac{3}{4}} 3^{\frac{1}{4}} t \right) \textit{\_C3} \right) \end{array}\right]
\end{document}
Which when compiled using texlive lualatex gives error. There is a missing \right.
>lualatex foo5.tex
This is LuaHBTeX, Version 1.12.0 (TeX Live 2020)
 restricted system commands enabled.
(./foo5.tex
LaTeX2e <2020-10-01> patch level 2
..Defaults to "dvips" Driver
(/usr/local/texlive/2020/texmf-dist/tex/latex/graphics/epsfig.sty (/usr/local/texlive/2020/texmf-dist/tex/latex/graphics/graphicx.sty (/usr/local/texlive/2020/texmf-dist/tex/latex/graphics/keyval.sty) (/usr/local/texlive/2020/texmf-dist/tex/latex/graphics/graphics.sty (/usr/local/texlive/2020/texmf-dist/tex/latex/graphics/trig.sty) (/usr/local/texlive/2020/texmf-dist/tex/latex/graphics-cfg/graphics.cfg) (/usr/local/texlive/2020/texmf-dist/tex/latex/graphics-def/dvips.def))))
Defining Automatic Style Generation Macros
Defining Maple Spreadsheet Environments
Maple Spreadsheet and Table Support
) (/usr/local/texlive/2020/texmf-dist/tex/latex/l3backend/l3backend-luatex.def) (./foo5.aux) (/usr/local/texlive/2020/texmf-dist/tex/latex/base/ts1cmr.fd)
! Missing \right. inserted.
<inserted text>
\right .
l.14 \\
Maple 2020.2, Physics 905
Fyi, the issues I know about in Latex()  as of now are these 4
https://www.mapleprimes.com/questions/231398-Regression-In-Latex-Between-897-And?sq=231398
https://www.mapleprimes.com/questions/231397-Latex-Latex-Generates-Command-Not-In
https://www.mapleprimes.com/questions/231273-Why-Latex-Fail-To-Convert-Solution
https://www.mapleprimes.com/questions/231262-Latex-Generates-Wrong-Latex-For-This-Example
