Question: another expression Maple can't simplify
I think Maple's simplify could need much more improvement.
Here is another example, which I can't get Maple to simplify to zero for positive x, when it is clearly zero there
ode:=x = (diff(y(x),x)^2+1)^(1/2)*diff(y(x),x);
mysol:=y(x)=_C1+int(  sqrt(-2+2*sqrt(4*a^2+1))/2,a=0..x);
check:=odetest(mysol,ode);
The above is zero for x>0
But I tried every assumption or option on it, and it will not give zero.
simplify(check) assuming x>0;
simplify(check,symbolic);
simplify(check,symbolic,sqrt) assuming x>0;
simplify(check,sqrt) assuming x>0;
simplify(check,radical) assuming x>0;
simplify(check,power) assuming x>0;
etc...
Here it is in Mathematica
ClearAll[x];
check = x - (Sqrt[2 + 2 Sqrt[4 x^2 + 1]]) (Sqrt[-2 + 2 Sqrt[4 x^2 + 1]])/4;
Simplify[check, Assumptions -> x > 0]
Why Maple can't simplify this to zero?  Is there some other specific trick one must use each time?
Maple 2020.2 on windows 10
