Question: Simple PASS FAIL Code file
Sorry file was not attached
ASME B31.3-2002 - Flexibility Analysis
This document considers the requirements for flexibility analysis of pipe work in accordance with standard ASME B31.3 2002 Edition.
Temperature Reduction for Swagelok fittings and tube.
Based on 316L Stainless steel fittings and tube, from Data Sheet MS-01-107 rev S and shown below a linear interpolation is used to determine the factor for operation at 100 and 130 centigrade.
with(Interpolation)
with(plots)
Temperature values from table. temp := [93, 204, 315, 426, 537]
Factor values from fable. fact := [1, .96, .85, .79, .76]
Graph of data points. pointplot(temp, fact)
facto := LinearInterpolation(temp, fact)
_m2344257169824
(1.1)
Factor for operation at 100 centigrade.facto(100) = HFloat(0.9974774774774775)NULL
Factor for operation at 130 centigrade. facto(130) = HFloat(0.9866666666666667)NULL
Swagelok compatability
From the B31.3 standard, Table 326.1 Component Standards, Swagelok fittings are not listed directly but it is considered that they are covered under the entry for Unified inch screw threads (UN and UNR thread form) with designation ASME B1.1. Stainless steel pipe is covered directly with designation ASME B36.19M.
Therefore the use of these parts is acceptable under the standard.
Specific Tube Sizes.
The initial specification suggests a DN15 tube size. This equates to 5/8", however the range of fittings in this size is limited. A preferred size would be to either go down to 1/2" or up to 3/4" tube. These will give an actual bore of ~10mm and ~15mm respectivly. In terms of the pressure and temperature specification the following information is provided from Swagelok data sheet MS-01-181.
1/2" x 0.049" wall pressure rating at 37C. TP05__37 := 3700*Unit('psi') = 3700*Units:-Unit(` psi `)NULL
3/4" x 0.065" wall pressure rating at 37C. TP75__37 := 3300*Unit('psi') = 3300*Units:-Unit(` psi `)NULL
Hence pressure ratings, converted to bar at 130C are:
TP05__130 := convert(TP05__37*facto(130), units, bar) = HFloat(251.70460624926636)*Units:-Unit(bar)NULL
TP75__130 := convert(TP75__37*facto(130), units, bar) = HFloat(224.49329746556185)*Units:-Unit(bar)NULL
Hence the tubing used in the design is acceptable.
Weld Fitting Specifications
There are several types of welded fittings as "Tee" "Reduceing Tee" and "Reducing Unions" and they have various pressure ratings.
A 3/4" tube butt weld "Tee" Tee75__37 := 2400*Unit('psi') = 2400*Units:-Unit(` psi `)NULL
The weld fittings have pressure rating at 130C of. Tee75__130 := convert(Tee75__37*facto(130), units, bar) = HFloat(163.2678527022268)*Units:-Unit(bar)NULL
Hence the weld fittings used in the design are acceptable.
Tube wall calculation
with(Units[Standard])
Determine the minimum wall thickness based on the design code.
Design pressure. P__D := 150*Unit('bar') = 150*Units:-Unit(bar)NULL
Outside diameter of nominal 3/4" tube. D__75 := 19.05*Unit('mm') = 19.05*Units:-Unit(mm)NULL
Quality factor. E := 1 = 1 for seamless stainless steel tube.
Allowable stress for 316L tube at 166C (300F). From B31.1 Table A1. S__allow := 115.14*Unit('MPa') = 115.14*Units:-Unit(MPa)NULL
Y__coeff := .4 = .4NULL
Miniumum wall thickness. t__min := P__D*D__75/(2*(E*S__allow+P__D*Y__coeff)) = 0.1179420505e-2*Units:-Unit(m)NULL
Actual wall thickness. W__75 := 1.65*Unit('mm') = 1.65*Units:-Unit(mm)NULL
if W__75 >= t__min then print(PASS) else print(FAIL) end if = PASSNULL``
NULLNULL
Conversions
From Appendix A
allowable stress for TP316L at 100C (212F).convert(16.7, units, ksi, MPa) = 115.1424468NULL
allowable stress for TP316L at room temperature.convert(25.0, units, ksi, MPa) = 172.3689323NULL
convert(18, units, m^3/h, L/minute) = 300NULL
convert(3300.0, units, psi, bar) = 227.5269907NULL
.58*% = 131.9656546NULL
convert(70.0, units, degF, degC) = 38.88888889NULL
convert(300.0, units, degF, degC) = 166.6666667NULL
convert(.117, units, Unit('dm'^3), Unit('L')) = .117NULL
with(ThermophysicalData:-Chemicals)
with(ThermophysicalData)
Property(MolarMass, He, useunits)
4.0026020*Units:-Unit(g/mol)
(3.1)
Property(density, Helium, temperature = 300*Unit(kelvin), pressure = 101325*Unit(Pa), source = CoolProp)
.1625153176*Units:-Unit(kg/m^3)
(3.2)
Helium flow rate. flow[he] := 300*Unit('L')/Unit('min')``
Determine molar flow rate. molflow[he] := .1625153176*flow[he]*Units[Unit](kg/m^3)/(4.0026020*Units[Unit](g/mol)) = .2030120876*Units:-Unit(mol/s)NULL
Determine mass flow rate. massflow[he] := 4.0026020*molflow[he]*Units[Unit](g/mol) = 0.8125765879e-3*Units:-Unit(kg/s)NULL
Property(MolarMass, CO2, useunits)
44.0095000*Units:-Unit(g/mol)
(3.3)
Property(density, CO2, temperature = 300*Unit(kelvin), pressure = 101325*Unit(Pa), source = CoolProp)
1.796636097*Units:-Unit(kg/m^3)
(3.4)
Property(MolarMass, Air, useunits)
28.9651159*Units:-Unit(g/mol)
(3.5)
Property(density, Air, temperature = 300*Unit(kelvin), pressure = 101325*Unit(Pa), source = CoolProp)
1.176995588*Units:-Unit(kg/m^3)
(3.6)
Determine the boiling point of water at 6 bar, the maxiumum pressure delivered by the cd90e unit.
boiling := Property(temperature, water, pressure = 6*Unit(bar), Q = 0)
431.9764773*Units:-Unit(K)
(3.7)
convert(boiling, temperature, Celsius)
158.8264773*Units:-Unit(`°C`)
(3.8)
evalf(convert(30, units, Unit('ft'^3/'min'), liters/s))
14.15842330
(3.9)
NULL
Input Parameters
Allowable stress for calculations. S[A] := evalf(f*(1.25*S[c]+.25*S[h]))`` = 219.82275*Units:-Unit(MPa)NULL
Allowable stress at minimum temperature. S[c] := 172.37*Unit('MPa')
Allowable stress at maximum temperature. S[h] := 115.14*Unit('MPa')
Stress reduction factor for N=7000 to 14000 cycles. f := .9
From Table C6 of standard, modulus of elasticity for stainless steel at room temperature.convert(28.3*10^6, units, psi, MPa) = 195121.6314NULL
Named as E[A] := 195121*Unit('MPa') = 195121*Units:-Unit(MPa)NULL
alpha[stst] := 16*10^(-6)*(Unit('m')*(1/(Unit('m')*Unit('K')))) = (1/62500)*Units:-Unit(1/K)NULL
Flexibility Stress
text##
S[E] := sqrt(S[b]^2+4*S[t]^2) =  = (S[b]^2+4*S[t]^2)^(1/2)NULL
Allowable stress factor for analysis requirement. K[allow] := 208000*S[A]/E[A] = 234.3321939NULL
Pipe diameter for 1/2" tube. D__A := 12.7*Unit('mm') = 12.7*Units:-Unit(mm)NULL
Pipe diameter for 3/4" tube. D__B := 19.05*Unit('mm') = 19.05*Units:-Unit(mm)NULL
Change in temperature. Delta[T] := 130*Unit('K') = 130*Units:-Unit(K)NULL
Section A1
Combined length of section A1.L[A1] := 110*Unit('mm')+119*Unit('mm') = 229*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[A1] := evalf(alpha[stst]*Delta[T]*L[A1]) = .4763200000*Units:-Unit(mm)NULL
U__A1 := 163*Unit('mm') = 163*Units:-Unit(mm)NULL
K[A1] := D__A*y[A1]/(L[A1]-U__A1)^2 = 0.1388719927e-2NULL
if K__A1 <= K__allow then print(PASS) else print(FAIL) end ifError, cannot determine if this expression is true or false: K__A1 <= K__allowNULL
Section A2
Combined length of section A2.L[A2] := 610*Unit('mm')+119*Unit('mm') = 729*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[A2] := evalf(alpha[stst]*Delta[T]*L[A2]) = 1.516320000*Units:-Unit(mm)NULL
U__A2 := 622*Unit('mm') = 622*Units:-Unit(mm)NULL
K[A2] := D__A*y[A2]/(L[A2]-U__A2)^2 = 0.1682004018e-2NULL
if K__A2 <= K__allow then print(PASS) else print(FAIL) end ifError, cannot determine if this expression is true or false: K__A2 <= K__allowNULL
Section A3
Combined length of section A3.L[A3] := 723*Unit('mm')+288*Unit('mm') = 1011*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[A3] := evalf(alpha[stst]*Delta[T]*L[A3]) = 2.102880000*Units:-Unit(mm)NULL
U__A3 := 778*Unit('mm') = 778*Units:-Unit(mm)NULL
K[A3] := D__A*y[A3]/(L[A3]-U__A3)^2 = 0.4919334672e-3NULL
if K__A3 <= K__allow then print(PASS) else print(FAIL) end ifError, cannot determine if this expression is true or false: K__A3 <= K__allowNULL
unwith(Units[Standard])
Length of section B. L[B] := 526*Unit('mm')`` = 526*Units:-Unit(mm)
Length of section C. L[C] := 1331*Unit('mm') = 1331*Units:-Unit(mm)
Length of section D. L[D] := 416*Unit('mm') = 416*Units:-Unit(mm)
Length of section E. L[E] := 526*Unit('mm') = 526*Units:-Unit(mm)
Length of section F. L[F] := 762*Unit('mm') = 762*Units:-Unit(mm)
Length of section G. L[G] := 287*Unit('mm') = 287*Units:-Unit(mm)
Length of section H. L[H] := 440*Unit('mm') = 440*Units:-Unit(mm)
Length of section I. L[I] := 400*Unit('mm') = 400*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[B] := evalf(alpha[stst]*Delta[T]*L[B]) = 1.094080000*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[C] := evalf(alpha[stst]*Delta[T]*L[C]) = 2.768480000*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[D] := evalf(alpha[stst]*Delta[T]*L[D]) = .8652800000*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[E] := evalf(alpha[stst]*Delta[T]*L[E]) = 1.094080000*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[F] := evalf(alpha[stst]*Delta[T]*L[F]) = 1.584960000*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[G] := evalf(alpha[stst]*Delta[T]*L[G]) = .5969600000*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[H] := evalf(alpha[stst]*Delta[T]*L[H]) = .9152000000*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[I] := evalf(alpha[stst]*Delta[T]*L[I]) = .8320000000*Units:-Unit(mm)NULL
K[B] := D[B]*y[B]/(L[B]-u[B])^2Error, (in Units:-Standard:-+) the units `mm` and `1` have incompatible dimensionsNULL
K[C] := D[C]*y[C]/(L[C]-u[C])^2Error, (in Units:-Standard:-+) the units `mm` and `1` have incompatible dimensionsNULL
K[D] := D[D]*y[D]/(L[D]-u[D])^2Error, (in Units:-Standard:-+) the units `mm` and `1` have incompatible dimensionsNULL
K[E] := D[E]*y[E]/(L[E]-u[E])^2Error, (in Units:-Standard:-+) the units `mm` and `1` have incompatible dimensionsNULL
K[F] := D[F]*y[F]/(L[F]-u[F])^2Error, (in Units:-Standard:-+) the units `mm` and `1` have incompatible dimensionsNULL
K[G] := D[G]*y[G]/(L[G]-u[G])^2Error, (in Units:-Standard:-+) the units `mm` and `1` have incompatible dimensionsNULL
K[H] := D[H]*y[H]/(L[H]-u[H])^2Error, (in Units:-Standard:-+) the units `mm` and `1` have incompatible dimensionsNULL
K[I] := D[I]*y[I]/(L[I]-u[I])^2Error, (in Units:-Standard:-+) the units `mm` and `1` have incompatible dimensionsNULL
Error, (in unwith) no package called `Units:-Standard' is currently bound
NULL
NULL
NULL
NULL
Download CALC-0191-Upload.mw
