Question: make simplify(expr,,trig) only simplify trig terms in expression?
I need to simplify terms such as (cos(x)^2+sin(x)^2) to 1 if present in input, but I do not Maple to also do any other simplification rewriting polynomials that might be present in the expression.
And example will make it clear. Given this
expr:= (cos(x)^2+sin(x)^2)+5+(1+x+x^2+x^3)*(cos(x)^2+sin(x)^2)*exp(x);
I want expr to become  6+(1+x+x^2+x^3)*exp(x).   i.e. only simplify trig terms
But simplify(expr,trig); gives
                 6 + (x + 1)*(x^2 + 1)*exp(x)
Which is not what I want. Then I tried the trick of thaw and freeze to tell Maple to freeze polynomial type, like this
thaw(simplify(subsindets[flat](expr,satisfies(Z->type(Z,polynom(integer, x))),(freeze))));
And it actually worked, giving
           6 + (x^3 + x^2 + x + 1)*exp(x)
Question is: Why did simplify(expr,trig) not do what expected, which is to only simplify trig terms in expression and not mess around with the polynomial there?
Is the above method of thaw/freeze to control which parts of expression gets simplify a recommended way to work around this, or is there a better way?
