Question: What exactly is the difference between `*` and `&*`?
Which one of these two versions, is the recommened one to use? For example, to check for type  integer*x, where x is literal x. i.e. identical(x)
TypeTools:-AddType('type_1', `&*`(integer,identical(x)));
type(3*x,type_1);
TypeTools:-AddType('type_1', '`*`'({integer,identical(x)}));
type(3*x,type_1)
Both work.  The difference is that `*` needs {} while `&*` does not.
I read the help page  and I do not understand what it says about the difference, and when is one supposed to use `*` vs. `&*`. it says
              | `*`(type)  a product of factors of the given type
              | `&*`(type*)  a product of factors in which the nth factor is of the nth type specified in type*
Could possibly someone please explain in simple plain english what is the difference? If I use `&*`  vs. `*` with {}, will they work the same all the time or are there cases when to use one vs. the other?  Any rules of thumb to follow?
