Question: how to get MacOS Big Sur 11.4 to recognize a package from saved worksheets? It works with new blank worksheets!
I'm having an issue with MacOS Big Sur 11.4 recognizing a package from saved documents. The package works great from new documents!
Specifically:
I've followed the instructions on
https://www.maplesoft.com/support/help/Maple/view.aspx?path=worksheet/reference/initialization
to add  a .mapleinit
file to my user home directory under MacOS Big Sur 11.4
The .mapleinit file has code as follows to run the VLA package:
VLAlibpath := "/VLA/library/":
libname := `VLAlibpath`, libname:
and I have the VLA package files with the library inside of it in my home directory too.
When I open a new Maple document and run and use the package, it works just fine!
The problem though is that if I save the Maple file and reopen it, it will no longer recognizes the package. I get:
Error, invalid input: with expects its 1st argument, pname, to be of type {`module`, package}, but received VLA
It is very odd since the file still recognizes the libname just fine:
libname;   "VLA/library/", "/Library/Frameworks/Maple.framework/Versions/2021/lib"
The workaround is to copy and paste into a new document and start a fresh but that is obviously not ideal.
Any ideas? It is a really really old package, but great for visualization.
Thanks,
Sarah
