Question: Subprocedures in a main procedure
How to add any/many subprocedure in a mainprocedure?
Somehow the mainprocedure must deliver the input for the mainprocedure
Here is a example
Note: probably can this old procedure be rewritten in modern Maple programming language ?
Code to Find the Max and Min Values in a List A
maxmin:=proc(A,maxv::evaln,minv::evaln)
   local i;
   maxv:=A[1]; minv:=A[1];
   for i from 2 to nops(A) do
     if eval(maxv) < A[i] then maxv:=A[i] end if;
     if eval(minv) > A[i] then minv:=A[i] end if;
   RETURN()
Now we can call the maxmin procedure from a procedure named optimize, which is designed to create the polygonal approximation, use maxmin to find the largest and smallest y-values from among the vertices, and produce some graphic output.
See the documentation in the book.
Code to Approximate the Max and Min Values of a Function  f :
optimize:=proc(f,a,b,N,pic::evaln)
  local X,Y,L,i,A,xmax,xmin;
  X:=array(0..N);Y:=array(0..N);L:=array(0..N);
  with(plots,display);
  for i from 0 to N do
    X[i]:=evalf(a+i*(b-a)/N);
    Y[i]:=f(X[i]);
    L[i]:=plot([[X[i],0],[X[i],Y[i]]],color=black):
  A:=[seq(Y[i-1],i=1..N+1)];
  maxmin(A,maxv,minv); # USE OF SECOND PROCEDURE --------------
  xmax:={};xmin:={};
    if Y[i]=maxv then xmax:=xmax union {X[i]} end if;
    if Y[i]=minv then xmin:=xmin union {X[i]} end if;
  end do; #----------------------------------------------------
  pic:=display({seq(L[i],i=1..N)}):
  print(`maximum y value is`,maxv,`and occurs at these x values`,xmax);
  print(`minimum y value is`,minv,`and occurs at these x values`,xmin);
Note that you must execute the code that defines maxmin before the procedure optimize will work. This only make sense.
We test the optimize procedure with the following function
f:=x->3+10*(-x^2+x^4)*exp(-x^2);
proc (x) options operator, arrow; 3+10*(-x^2+x^4)*exp(-x^2) end proc
on the interval [-1, 4].
optimize(f,-1,4,150,pic);
`maximum y value is`, 6.088066652, `and occurs at these x values`, {1.633333333}
`minimum y value is`, 1.391538737, `and occurs at these x values`, {-.6333333333, .6333333333}
pic;
Download procedure_en_subprocedures.mw
