Question: How do I Solve PDE Equation using Finite Difference Method in Maple?
Hi, I have problem at this coding. Can you help me?
eq1 := diff(u(u, t), t) = A[0] + A[1]*cos*omega*t + Beta[1]*[diff(u(u, r), r $ 2) + diff(u(u, r), r)/r];
                  d
          eq1 := --- u(u, t) = A[0] + A[1] cos omega t
                  dt
                       [                  d         ]
                       [/  2         \   --- u(u, r)]
                       [| d          |    dr        ]
             + Beta[1] [|---- u(u, r)| + -----------]
                       [|   2        |        r     ]
                       [\ dr         /              ]
The*number*of*node*points;
N := 4;
                             N := 4
The*length*of*domain;
L := 1;
                             L := 1
BC1 := u(1, t) = 0;
                       BC1 := u(1, t) = 0
IC1 := u(r, 0) = 0;
                       IC1 := u(r, 0) = 0
dudt := (u[m + 1] - u[m])/(delta*t);
                            u[m + 1] - u[m]
                    dudt := ---------------
                                delta t
dudr := (u[m + 1, j] - u[m - 1, j])/(2*delta*r);
               dudr := -------------------------
                               2 delta r
d2udr2 := (u[m + 1, j] - 2*u[m] + u[m - 1, j])/(delta*r^2);
                    u[m + 1, j] - 2 u[m] + u[m - 1, j]
          d2udr2 := ----------------------------------
                                        2
                                 delta r
Three point forward and backward difference expressions for the derivative are:
Error, unable to parse
Typesetting:-mambiguous(Typesetting:-mambiguous(
  Three point forward and backward difference expressions for,
  Typesetting:-merror("unable to parse")) the derivative arecolon)
dudrf := (-u[2] + 4*u[1] - 3*u[0])/(2*delta*r);
                         -u[2] + 4 u[1] - 3 u[0]
                dudrf := -----------------------
                                2 delta r
dudrb := (u[N - 1] - 4*u[N] + 3*u[N + 1])/(2*delta*r);
                         u[3] - 4 u[4] + 3 u[5]
                dudrb := ----------------------
                               2 delta r
The*governing*equation in finite*difference*form*is;
Eq[m] := subs(diff(u(u, t), t) = dudt, diff(u(u, r), r) = dudr, diff*(u(u, r), r $ 2) = d2udr2, eq1);
         u[m + 1] - u[m]                                     [
Eq[m] := --------------- = A[0] + A[1] cos omega t + Beta[1] [
             delta t                                         [
  / d  /u[m + 1, j] - u[m - 1, j]\\   u[m + 1, j] - u[m - 1, j]]
  \ dr \        2 delta r        //             2              ]
                                             2 r  delta        ]
The*boundary*condition in finite*difference*form*are;
Eq[0] := subs(diff(u(r), r) = dudrf, u(r) = u[0], BC1);
                      Eq[0] := u(1, t) = 0
The*initial*condition in finite*difference*form*are;
Eq[N + 1] := subs(diff(u(r), r) = dudrb, u(r) = u[0], IC1);
                      Eq[5] := u(r, 0) = 0
for i to N do
    Eq[m] := subs(m = i, Eq[m]);
           u[2] - u[1]
  Eq[m] := ----------- = A[0] + A[1] cos omega t + Beta[1] [0]
             delta t
           u[2] - u[1]
             delta t
           u[2] - u[1]
             delta t
           u[2] - u[1]
             delta t
The node spacing is given by:
          The node spacing is given by,
          Typesetting:-merror("unable to parse"))colon)
h := L/(N + 1);
                                  1
                             h := -
                                  5
eqs := seq(evalm(subs(Beta = 0.25, Eq[i])), i = 0 .. N + 1);
  eqs := u(r, 0) = 0, Eq[1], Eq[2], Eq[3], Eq[4], u(r, 0) = 0
vars := seq(u[i], i = 0 .. N + 1);
           vars := u[0], u[1], u[2], u[3], u[4], u[5]
soll := fsolve({eqs}, {vars});
Error, (in fsolve) {r, Eq[1], Eq[2], Eq[3], Eq[4]} are in the equation, and are not solved for
