Question: why DEtools:-odeadvisor returns linear on this ode? This causes call to convertAlg to FAIL
I changed today my code to use DEtools:-odeadvisor(ode,y(x),[linear]); to check that the ode is linear or not before calling DEtools:-convertAlg
The problem is that sometimes the advisor returns _linear on what is not linear ode (at least the way it is originally written). Here is an example
              (x+y(x))*diff(y(x),x) = 0;
From help page:
In the event that convertAlg cannot isolate for the proper list form (for instance, if the DE is not a linear ODE) then FAIL is returned.
So now I am worried  that using odeadvisor to check for linear ode is not the right method.
Is there a build-in method in Maple to check if an ode is linear or not? (I do have my own code to do this, but I thought it is better to use a buildin method, as it will be more robust).
Should DEtools:-odeadvisor(ode,y(x),[linear]) have returned _linear in this case?
interface(version);
`Standard Worksheet Interface, Maple 2022.1, Windows 10, May 26 2022 Build ID 1619613`
ode:=(x+y(x))*diff(y(x),x) = 0;
DEtools:-odeadvisor(ode,y(x));
#check if linear ODE
(x+y(x))*(diff(y(x), x)) = 0
[_quadrature]
[_linear]
DEtools:-convertAlg(ode,y(x));
FAIL
Download why_fail_sept_17_2022.mw
