Question: substitution of physics matrix multiplication with the default one
Hey guys, in the following expression
with(Physics[Vectors]);
Setup(mathematicalnotation = true);
with(Physics);
Setup(op = {Omega, r});
lprint(m*Omega^2*r);
which outputs this:
i want to substitute  Physics:-`*` which is an overloaded version of matrice multiplication with the default one which is `.` so I wrote the following code :
use   `*`= :-`.` in
a := m*Omega^2*r
end use
the result is the same and its not substitute the physics product with the default one. what is the mistake here?
I also tried the following code and its worked. but I want to make it work with the 'use' function for general purposes
lprint(m . (:-`.`(Omega^2, r)))
thanks in advance
