Question: "select" command doesn't work as expected in Physics symbols
hello maple world, in the following code (code attached at the bottom) i wish to select the terms which have the term so i used the "select" command for this task
but as u can see from the results it also selects other terms which is wrong. so what is the mistake here
thanks in advance
Physic_select.mw
