Question: Is this an endpoint of function composition?
Example
diff(w(x), x, x) = F*((6*(-a^2/(2*L^2)+a^3/(3*L^3)))*x+2*a^2/L-a^3/L^2)/EI
diff(diff(w(x), x), x) = F*(6*(-(1/2)*a^2/L^2+(1/3)*a^3/L^3)*x+2*a^2/L-a^3/L^2)/EI
Eval(lhs(diff(diff(w(x), x), x) = F*(6*(-(1/2)*a^2/L^2+(1/3)*a^3/L^3)*x+2*a^2/L-a^3/L^2)/EI), x = L) = (`@`(simplify, eval))(rhs(diff(diff(w(x), x), x) = F*(6*(-(1/2)*a^2/L^2+(1/3)*a^3/L^3)*x+2*a^2/L-a^3/L^2)/EI), x = L)
Eval(diff(diff(w(x), x), x), x = L) = -F*a^2*(L-a)/(L^2*EI)
Can the expression above be further shortened by function composition and function application (to a single group of arguments)? I tried
(`@`(Eval, lhs) = `@`(`@`(simplify, eval), rhs))(diff(diff(w(x), x), x) = F*(6*(-(1/2)*a^2/L^2+(1/3)*a^3/L^3)*x+2*a^2/L-a^3/L^2)/EI, x = L)
Error, (in evalapply) invalid input: lhs expects 1 argument, but received 2
which does not work.
Since the error message is clear I am looking for a single argument command that could replace lhs and rhs.
Analog to evalf, which accepts an index, I tried to replace lhs by
op[1](diff(diff(w(x), x), x) = F*(6*(-(1/2)*a^2/L^2+(1/3)*a^3/L^3)*x+2*a^2/L-a^3/L^2)/EI)
diff(diff(w(x), x), x), F*(6*(-(1/2)*a^2/L^2+(1/3)*a^3/L^3)*x+2*a^2/L-a^3/L^2)/EI
(3)
to do the same as
op(1, diff(diff(w(x), x), x) = F*(6*(-(1/2)*a^2/L^2+(1/3)*a^3/L^3)*x+2*a^2/L-a^3/L^2)/EI)
(4)
Unfortuenatly this does not work. Are there any other options or have I reached an end point?
Would a single argument variant of op make sense for other purposes than the example above?
Download replacement_of_lhs_and_rhs_by_single_argument_function.mw
