Question: How to apply initial conditions to a flexible beam?
I was not able to apply ICs (initial conditions) using the advanced parameter settings of the flexible beam component in the attached file. My intention is to have a beam moving at t=0s (velocity of end frame <> 0). The computed initial values for the elastic coordinates (see output console for the disabled component below encircled in red) indicate that the flexible beam has no kinetic energy at t=0s.
A workaround is to attach a rigid body to the end frame and apply the ICs to the body. (Inertia and mass of the rigid body can be set to zero.)
How to apply initial conditions to the disabled component so that it moves as the workaround?
Imposing_IC_v.msim
