Question: Exporting Graphs to PDF Using Maple Code?
The following code effectively converts the image to the JPG format.
with(GraphTheory):
s:=DrawGraph(CompleteGraph(5),size=[250,250])
Export("D:\\s1.jpg",s)
But I would like to export it using PDF format. However, the modified code below seems to be quite unsuccessful. I am aware that Maple has export options in the front end, but I still prefer to use code for this purpose.
Export("D:\\s1.pdf",s)
Error, (in Export) invalid input: member received _ImportExport:-InfoTable["PDF"][4], which is not valid for its 2nd argument, s
There are two reasons for this.
with(GraphTheory):
Graphs:=[NonIsomorphicGraphs(6,8,output=graphs,outputform = graph)]:
num_g:=nops(Graphs):
num:=ceil((num_g)/5.):
Matrix (num,5,(i,j)->`if`((i-1)*5+j<=num_g, DrawGraph(Graphs[(i-1)*5+j],size=[250,250] ,overrideoptions ,showlabels=false,style=planar, stylesheet =  [
 vertexcolor     = orange
,vertexfontcolor = black
,vertexborder    = false
,edgethickness   = 0.6
,edgecolor       = MidnightBlue
,vertexshape     =  "circle"
,vertexfont      = [Arial, 4],
vertexthickness=5], caption = cat(H__,5*(i-1)+j),captionfont=["ROMAN",7]),plot(x = 0 .. 1, axes = none))):
DocumentTools:-Tabulate (M1[1..5,.. ],widthmode=percentage ,width=80 , exterior =all):
