Question: why infolevel stops working second time on some ode's?
I wonder if this a bug or Am I overlooking something?
I set infolevel[dsolve]:=5; and first time calling dsolve(ode), it works as expected. It prints on the screen the trace and steps it did.  But when I repeat the command dsolve, now it only prints one line and the rest of info that were printed before no longer show.
Should not the same information be printed each time? This is what happens on another example I tried. It seems infolevel does not work the same depending on the ode being solved?  Here is a worksheet attached to show the above.
Is there a workaround to make it display same information each time?
Maple 2023.2 on windows 10.
21424
interface(version);
`Standard Worksheet Interface, Maple 2023.2, Windows 10, October 25 2023 Build ID 1753458`
ode:=[2*diff(x(t),t)+diff(y(t),t)=x(t)+y(t)+t,diff(x(t),t)+diff(y(t),t)=2*x(t)+3*y(t)+exp(t)];
dsolve(ode);
[2*(diff(x(t), t))+diff(y(t), t) = x(t)+y(t)+t, diff(x(t), t)+diff(y(t), t) = 2*x(t)+3*y(t)+exp(t)]
5
-> Solving each unknown as a function of the next ones using the order: [y(t), x(t)]
-> Calling odsolve with the ODE diff(diff(y(x) x) x) = 4*(diff(y(x) x))-y(x)-3*x+1 y(x) singsol = none
Methods for second order ODEs:
--- Trying classification methods ---
trying a quadrature
trying high order exact linear fully integrable
trying differential order: 2; linear nonhomogeneous with symmetry [0,1]
trying a double symmetry of the form [xi=0, eta=F(x)]
-> Try solving first the homogeneous part of the ODE
   checking if the LODE has constant coefficients
   <- constant coefficients successful
   -> Determining now a particular solution to the non-homogeneous ODE
      trying a rational particular solution
      <- rational particular solution successful
<- solving first the homogeneous part of the ODE successful
{x(t) = exp((2+3^(1/2))*t)*c__2+exp(-(-2+3^(1/2))*t)*c__1-3*t-11, y(t) = -(1/2)*exp((2+3^(1/2))*t)*c__2*3^(1/2)+(1/2)*exp(-(-2+3^(1/2))*t)*c__1*3^(1/2)-(3/2)*exp((2+3^(1/2))*t)*c__2-(3/2)*exp(-(-2+3^(1/2))*t)*c__1-(1/2)*exp(t)+2*t+7}
dsolve(ode);
5
dsolve(ode);
dsolve(ode);
ode:=diff(y(x),x$2)+y(x)=sin(x);
dsolve(ode);
diff(diff(y(x), x), x)+y(x) = sin(x)
trying a quadrature
      building a particular solution using variation of parameters
y(x) = sin(x)*c__2+cos(x)*c__1+(1/2)*sin(x)-(1/2)*cos(x)*x
dsolve(ode);
trying a quadrature
On a side note. the first line of the display is hard to read. Any one know what it is supposed to mean by the space between the 1 and y(x) at the end there?
Download infolevel_stops_working.mw
Another example where infolevel changes on second call to dsolve: The first call gives more information which is lost in the second call. There does not seem to be a way to fix this at user level.
23828
ode:=diff(y(x),x)+(a*x+y(x))*y(x)^2=0:
infolevel[dsolve]:=5:
dsolve(ode)
Methods for first order ODEs:
trying a quadrature
trying 1st order linear
trying Bernoulli
trying separable
trying inverse linear
trying homogeneous types:
trying Chini
differential order: 1; looking for linear symmetries
trying exact
trying Abel
The relative invariant s3 is: -1/27*a*(2*a^2*x^3-9)
The first absolute invariant s5^3/s3^5 is: 729*a^4*x^6*(2*a^2*x^3-15)^3/(2*a^2*x^3-9)^5
The second absolute invariant s3*s7/s5^2 is: 5/3/a^2*(2*a^2*x^3-9)/x^3*(2*a^4*x^6-21*a^2*x^3+18)/(2*a^2*x^3-15)^2
...checking Abel class AIL (45)
...checking Abel class AIL (310)
...checking Abel class AIR (36)
inverse of the transformation solving the problem is: {t = 1/2*(-2*a^2)^(1/3)*x, u(t) = -(-2*a^2)^(1/3)/a*y(x)}
<- Abel successful
y(x) = 2*a/(a^2*x^2+2*RootOf((-2*a^2)^(1/3)*AiryBi(_Z)*c__1*x+(-2*a^2)^(1/3)*x*AiryAi(_Z)+2*AiryBi(1, _Z)*c__1+2*AiryAi(1, _Z))*(-2*a^2)^(1/3))
dsolve(ode)
trying a quadrature
trying Bernoulli
trying separable
trying Chini
trying exact
trying Abel
<- Abel successful
Download another_example_info_level_changes.mw
